KRPO serial outputs codes
Posted: Wed Sep 21, 2016 3:54 am
by amoras10
Hello,
Im using KPRO v4, also serial outputs you have described in help (Serial Output topic)
But i couldn't find serial output packet description which is related to
Oil pressure ?
and
Check engine, is this MIL?
thanks
Re: KRPO serial outputs codes
Posted: Wed Sep 21, 2016 9:03 am
Oil pressure the ECU does not know. MIL is the same as check engine light.
Posted: Wed Sep 21, 2016 1:04 pm
by amoras10
i see.
oil pressure light serial out is missing then...
Posted: Wed Sep 21, 2016 1:41 pm
by D-Rob
The ECU doesn't get signal from the oil pressure switch. That goes directly to the cluster.
Posted: Thu Sep 22, 2016 1:04 pm
by amoras10
i see your point.
asking because making custom diy race dash with laptimer, dataloging to pits etc.
maybe some1 neeed?
https://youtu.be/SZ0GuOItgTQ
