afr going to lean on boost
Posted: Tue Sep 20, 2016 7:08 pm
by tweenpix
at some length AFR ~ 10-11 the indicator shows LEAN.
it's probleme of calibration or fuel pump or wideband?
thanks
f22turbo111-v9.skl
f22turbo111-v9-160921-071703.s3d
SOLVED:
probleme in bad fuel pump
Re: afr going to lean on boost
Posted: Wed Sep 21, 2016 9:12 am
It is a rev limiter at the point in the datalog about (11:10) Disable launch control and the speed limiter see if that helps.
Posted: Thu Sep 22, 2016 12:18 am
by tweenpix
ok, i try it
Posted: Thu Sep 22, 2016 7:44 am
by tweenpix
same probleme
if you can, please look log file
need replace fuel pump?
f22turbo111-v11.skl
f22turbo111-v11-short-log.s3d
Posted: Thu Sep 22, 2016 9:06 am
Only problem I see is at 2:35 which is a boost cut.
Posted: Thu Sep 22, 2016 5:57 pm
by tweenpix
Hondata wrote:Only problem I see is at 2:35 which is a boost cut.
thank you very much
but boost cut on settings = 1600 mbar
on 2:35 maximum boost is 1592 mbar
Posted: Sat Sep 24, 2016 4:56 pm
The datalog shows the MAP at a far lower sample rate than what the ECU sees. The datalogged MAP was 99.5% of the boost cut pressure, but there was one or more values at 1600 or higher pressure.
Posted: Sat Sep 24, 2016 9:54 pm
by tweenpix
thank you very much
i find my probleme
the fuel pump is bad - flow is 90 lph on 43 psi
need replace
thanks again
