Problems with my s300
richardmichalski19
Post by richardmichalski19 »
I need help w my s300 I plug it in it connects online but when I start the car I get a check engine light when I start the car if I put a stock p28 on it there is no light so with that being said the car idles up and stays there I cant get any thing to work to adjust it is there away to.delete it i can data log but the problem is the graphs don't work and
Paremeters dont either Nothing is working with the motor I change somethings after I hit the upload button and nothing happens not sure why it won't work
richardmichalski19
Re: Problems with my s300
ok I'm in the car no It wont let me see it at real time on it and the light is red I tried erasing and started over also it would not erase the ecu
I want to know what I can do to get it to connect right please someone help me
did I get ripped off with my ignition on it says online and also driver installed I don't know what I'm doing wrong I unistalled
and reinstalled it now I know I need help
richardmichalski19
Well I got it to work I had to erase ecu and keep uploading it finally worked but I'm having troubles setting up my
Vtec it won't load up the changes that I make thank u man for helping me
Spunkster wrote:What is the serial number that is on the s300 board inside the ECU?
richardmichalski19
S300 13042 that's the number I just need help how to adjust the vtec I'm trying to learn how.to tune it a lil bit
richardmichalski19
so the reality is I just want some help understanding this software ! I need it in lamen terms I want to be hondata literate there is not many
movies on it so if you can help me along would be amazing thank you for your hit I need help bad thanks again I'm such a noob
richardmichalski19
Need help please everytime i.shut my car off the engine light comes on and the ecu dosent save the calibration
the ecu is red I have to erase it all the time and delete the data log
It sounds like the battery is bad in the s300. You will need to upgrade to the s300v3 in order to get this to work properly.
Details on upgrading can be found at: https://www.hondata.com/downloads/s300v ... e_form.pdf
