Upload password not accepted
HRD
Post by HRD »
I have a very strange problem with my S300 V3.
Two years ago, I protected the upload by password. Yesterday I had to work with it normally and recorded a datalogs. Today I download the information and then changed the rev limit when trying to upload to the ecu the S300 does not recognize my password. Send an error message.
Also in datalogs list appeared a very strange record with with (-30) minutes of recording and (-30000k).
What can I do and what could have caused this?
Re: Upload password not accepted
What is the serial number on the s300 board inside the ECU?
HRD
Post by HRD »
Here is some data in the attached image.
Also on the owner tab also disappeared the data and got a zero. Do not let me reset the password by not having the owner data and then do not let me upload the data by the password not be correct.
Download the most recent version of software from the software section of the website and try using that software with it and see if that resolves the issue.
HRD
Post by HRD »
I already tried today with the new and installed again the driver but does not work. I also tried to remove the ECU data, but did worse, now the car is no more than 3500 rpm and can not upload.
What happens if you try to enter new owner info and update it?
HRD
Post by HRD »
When I try to enter the owner data again he asked me to enter the password and after give me this error:
When I fill out everything and try to recover the password the program gives this:
When I try to recover the password:
When I try to change the password give me this:
With the everything plugged in and the key on, go to Help, and click on send information to Hondata support. Include a detailed description of the problem.
HRD
Post by HRD »
Ok,i will do it! Thks any way
watchout221
Post by watchout221 »
was this ever solved? im having the same issue my s300 has green check marks on all three of the security but my info is gone my password doesn't work I can update the info or load a map I completely wiped my laptop smanager is the only program ive installed and still same issue.. and I just wanna drive my any help would be great.
With the S300 plugged in and the ignition on, can you use the 'Send Support Information to Hondata' function from the help menu. Also post your serial number here so we can cross reference it.
watchout221
I believe I can send information from ecu but how would i know for sure it went through and you guys received it? The serial # 31801. And from help the software 2.6.6.0 witch I downloaded just the other night useing a different laptop just in case mine was the issue.
have you tried to send it?
watchout221
Yeah i just sent it
