Hey guys,
Noticed that rpm recover in launch control settings are no longer there. Rpms bounce quite slow.
09 fg2 running most recent update/ with hybrid map
Launch Control rpm recovery gone
Re: Launch Control rpm recovery gone
The recovery rpm is now the same as the limit rpm for the launch limiter.
I don't seem to see a launch limiter or limit rpm besides overall limiterHondata wrote:The recovery rpm is now the same as the limit rpm for the launch limiter.
Still lost... so there is not a actual recover RPM.. you can move the launch rmp up in incitements of 100 but the recover will always been the same 300ish around rmp from witch you set the "launch rpm (adjustable) from.Hondata wrote:"Launch rpm (adjustable)"
RTUNED-FD2R
Hi, is there plans to put the launch limit recovery option back into the program in the future? Thanks.
