S300 - no green light next to usb
Posted: Thu Aug 11, 2016 11:03 am
Hi, I have been having trouble the past few days trying to get my car to start, 94 eg s300 p28 with CPR kit fitted and boost by gear.
After a rebuild on the engine I have tried to start the engine and it just cranks over with no spark. Getting fuel and feed back to CPR IGN light pulsing correctly but no SYNC light on. Then after some checking of wires, pins, sensors, earths, voltages, and main relay all were fine. Plugged in the Smanager to see what was happening and get a notification 'Ecu connected' but when going on to datalogging nothing happens, it says IAT and ECT 302 degrees and no repose from TPS or brake switch. When on ignition key it has a constant eml even when service connector linked and no codes on Smanager. While troubleshooting following many guides on this forum I found the s300 only has led d4 lit up. No green light at d2 and only getting 1 red flash from d1 when connecting the usb to laptop. Then flashing red when trying to datalog.
Is this a bad Ecu/s300. Any help and advice welcome.
Thanks for reading
Thanks for reading
