Fuel Injection restart RPM
Posted: Wed Aug 10, 2016 6:16 pm
by teddytao18
As I drove my reflashed Si, I noticed that there is a slight acceleration at about 1300 rpm, when I was braking or coasting in gear. I am not comfortable with it, and want to lower it to 1000 so that I can spend more time in gear without shifting to neutral. Anyone knows what I need to change?
Re: Fuel Injection restart RPM
Posted: Thu Aug 11, 2016 7:49 am
by pepperdanky
See "Injector Overrun Cutoff" here: https://www.hondata.com/help/flashpro/t ... meters.htm
The engine may stall when coming to idle if you lower the recover rpm below 1300.
Posted: Thu Aug 11, 2016 4:54 pm
by teddytao18
I tried that, it didn't seem to work. I still felt the acceleration at about 1300 rpm, and the power monitor in the imid confirmed it.
Posted: Fri Aug 12, 2016 9:36 am
by pepperdanky
Then 1300 rpm may be the lower limit of what the ECU will allow.
