Please help review Datalog - nuisance engine cut?
Posted: Fri Jul 22, 2016 5:32 am
by Lyle_57IAL
Hey guys,
Currently have some issues with my tune. Turbo D16 With Dry nitrous on Aux output. I find repeatability always in 4 gear around 5800 RPM my car will hit some type of protection however i have no idea what?
Could someone review the tune as well as datalogs and tell me if they can see anything?
Thanks hondata all the best
Re: Please help review Datalog - nuisance engine cut?
Posted: Fri Jul 22, 2016 9:27 am
What time stamp in the datalogs are you seeing the problem?
Posted: Fri Jul 22, 2016 2:19 pm
by Lyle_57IAL
Log 1 is 6:17
Log 2 is 1:28
Posted: Fri Jul 22, 2016 4:26 pm
Why do you have 2 different VTEC activation RPM points with the same Map values?
Have you also tried disabling the lean protection to see if this goes away?
Posted: Fri Jul 22, 2016 5:23 pm
by Lyle_57IAL
Yes i was thinking this as well. Have not tried removing lean protection ? the logs show I'm well below the lean cut anyway ?
Posted: Tue Jul 26, 2016 11:56 pm
by Lyle_57IAL
the vtec points & lean cut does not impact this problem..... any other ideas ? can the traction control be impacting this somehow?
Posted: Wed Jul 27, 2016 8:49 am
It is not a ECU cut, as the injectors stay on. The AF goes lean during the cut which would indicate a misfire. Overall timing is fairly low (4 degrees) and I'm wondering if the fire is going out.
