2012 si -flashpro tune
Domtorres1221
Post by Domtorres1221 »
Hey guys,
I have a 2012 si and just bought a short ram intake and invidia q300 catback. I also purchased flashpro for these as well as whatever future mods I get. Flashpro has preset calibrations, one tune in particular which is for short ram, and catback systems. I'm curious if this tune would be safe to use with stock exhaust/cat? Any input would help. Thanks!
Re: 2012 si -flashpro tune
YOu will have to try it and datalog to make sure it has a safe AF ratio and there is no detonation.
CAMGARNER
Post by CAMGARNER »
YES WILL BE SAFE...WHAT IS YOUR AFR AT WOT?...LET ME KNOW IF I CAN HELP...
Domtorres1221
Thanks for the reply guys !
Afr 14.5 -14.8:1 @ idle
Afr 13.0 - 13.5:1 @ WOT
Seems about right to me, what do you think?
Took it for a drive with this tune, & can definitely feel a good difference in the drive compared to stock equivalent or reflash
CAMGARNER
Post by CAMGARNER »
Not bad..I'd maybe dial in wot just a tad more...
Domtorres1221
Vtec seems to hit at 4k with this tune from 3gear on. Seem right? Anyone familiar with this calibration?
carlosfb6
Post by carlosfb6 »
Spunkster wrote:YOu will have to try it and datalog to make sure it has a safe AF ratio and there is no detonation.
I was trying this one out on my 2013 si and it seems to have some sort of miss fire is it because it uses the map sensor it seems to work fine for about 10 minutes of driving then it starts to run weird
