Page 1 of 2
Kpro 4 lost bluetooth connection and digital wideband input
Posted: Mon Jul 18, 2016 1:07 pm
by jbt
Today my kpro 4 lost it's ability to connect to the app or my computer via bluetooth. At the same time it also lost the connection to my PLX wideband. The PLX controller feeds the Kpro through the digital input channel. In the app the kpro is not found and on the computer the kpro is found but I get a error message when I try to connect. The message says "could not connect via bluetooth (10060)"
I have tested the PLX controller and wideband sensor and it's working as it should through the analog output, haven't tested the digital output though.
Any ideas what to do?
Re: Kpro 4 lost bluetooth connection and digital wideband input
Posted: Mon Jul 18, 2016 1:29 pm
What is the serial number that is on the K-Pro board onside the ECU?
Posted: Mon Jul 18, 2016 11:36 pm
by jbt
40034
4.2.6.0
Posted: Tue Jul 19, 2016 9:37 am
Are you able to datalog in Kmanager via USB and upload to the ECU?
Posted: Tue Jul 19, 2016 12:41 pm
by jbt
At the moment I can datalog via USB and upload. But when I discovered the problem I also had problems connecting through USB. Sometimes it connected and sometimes not. So I updated my kmanager software first to the 4.2.5 version which didn't work at all (kmanager crashed when trying to upload), and then to the latest version which worked. I think it also updated the firmware in the ECU at the same time. Since then I have been able connect via USB and upload to the ecu.
I also tried uploading another calibration to the ECU to see if there was any difference but nothing changed.
Posted: Tue Jul 19, 2016 12:54 pm
When you click the K-Pro button in Kmanager and then go to the Bluetooth tab, what shows up?
Posted: Mon Jul 25, 2016 8:57 am
by jbt
This is how it looks in the bluetooth window
Posted: Mon Jul 25, 2016 9:25 am
Try changing the PIN to 0000 and then reconnect via Bluetooth.
Posted: Mon Jul 25, 2016 11:22 am
by jbt
Didn't work.
The wideband digital input is still lost also.
Posted: Mon Jul 25, 2016 4:34 pm
Try disconnecting the digital input plug from inside the ECU and see if the Bluetooth works.
Posted: Tue Jul 26, 2016 8:04 am
by jbt
Disconnecting the digital plug from the kpro board but it didn't help.
Posted: Tue Jul 26, 2016 3:49 pm
Can you see it listed as a device to connect to using the app?
Posted: Tue Jul 26, 2016 10:55 pm
by jbt
No.
Posted: Wed Jul 27, 2016 7:10 am
by jbt
Now the bluetooth suddenly started to work again. The only thing that I have done is reloading the software a couple of times and trying to get the wideband to work. I wonder if it's something wrong with the kpro board or software?
But I still don't have any wideband. I have changed the wideband from digital to analogue but I still don't get any value. I also tried the analogue 0 as raw voltage but it says 0 although I get 3.5v when I measure with a multimeter.
Posted: Wed Jul 27, 2016 9:46 am
Post your calibration as well as a datalog showing the issue. Have you gone back and looked at old datalogs to see if you can see the data in those?
