expert datalog readers*
Hondatuner_1
HI, My vehicle began to run lean under load for some reason unknown. I am hoping ya'll may find something in datalog.
Re: expert datalog readers*
I would recommend cleaning your wideband sensor with brake cleaner to see if that will help. I had the same problem recently, I changed the fuel pressure regulator and even the fuel pump and it would still lean out. If cleaning the sensor works I recommend getting a new one.
