Race Dash
keithc
Race Dash
Post by keithc »
Hi all,
I have a race car with a DC5 Integra Engine and ECU.
I want to fit a proper race dash so I can get rid of all the guages and datalog etc.
Problem is none of the Dash manufacturers support the Jap spec ECU "PRC"
Question is could I just get a "PRB" ecu from a EP3 Civic (they all seem to support this model ecu) and load my current map onto it!?
I know the fuel pump is wired slightly different but that is easy changed, I'm not currently running a Lambda.
Cheers
Keith
Re: Race Dash
keithc
Re: Race Dash
Post by keithc »
Ah ok thanks,
with version 3 it matters tho!!
Cool ill prob just upgrade to version 4 K-Pro
Will I have to get the K-Pro 4 remapped or can I load my original map onto it.
Don't know if maps are intechangable from different versions K-Pro
Re: Race Dash
You can use your existing calibration with the new K-Pro.
keithc
Re: Race Dash
Post by keithc »
Excellent
Thanks for your Help
Keith
keithc
Re: Race Dash
Post by keithc »
Will the AIM/Hondata adaptor module work with the "PRC" ecu!?
Would be alot cheaper option than upgrading to Kpro4
I have v3
Re: Race Dash
You could use that, but the details are no longer n the help file.
keithc
Re: Race Dash
Post by keithc »
I have found old threads showing what settings etc.
And aim have the wiring diagram.
Main thing is it will work with the JAP PRC ecu
Re: Race Dash
It is dependent on the calibration used I believe, not the actual ECU.
keithc
Re: Race Dash
Post by keithc »
Ah ok, I'll check that altho I think the calibration used us prc
Re: Race Dash
There are no PRC calibrations, only PRB, PNF, and PND.
keithc
Re: Race Dash
Post by keithc »
Oh right ok. I'll check tomorrow
keithc
Re: Race Dash
Post by keithc »
Might be a stupid question but how do I check what calibration is on my ecu!?
keithc
Re: Race Dash
Post by keithc »
It's ok I found it.
Found it in the notes.
It's a PRB calibration type
