After a long time of not posting, here is the 332wHP Tune I had on 7lbs boost on E85
All stock internals, bolt ons include:
74mm Skunk2 Pro TB
74mm Skunk2 Ultra Intake Manifold
1000cc Grams Injectors
3" Intercooler Piping
Large Intercooler
Godspeed T3/T4 Turbo
2.5" Down pipe, ran all the way back with muffler, no cat/resonator
7lbs Spring
Any questions, feel free to ask.
B20V (B20/B16) Turbo 7lbs Tune
B20vincali
Re: B20V (B20/B16) Turbo 7lbs Tune
Thank you. That is close to our setup. Will try use this as a basemap. ta
Tim
http://www.s2kuk.com
http://www.ludegeneration.co.uk
Aren't these fuel values very large overall when compared to stock ? I would have thought with 1000cc injectors the fuel values would be lower?
Tim
High value fuel because of e85 i think but thanks for posting doing a stock with bolt ons b20v right now going to use this base map to drive the car to the dyno
Zperformance
In my opinion, one of the better tunes i seen so far on the site. jw was this tune on a dyno. Whatsup with the same timing value on vtec?
watchout221
quick question could i use this map on my b16a2 and using pump gas?
mods list
dropped compression
eagle rods
head studs
4bar map
SF ram horm
1000cc grams
255 grams
aem rail & fpr
3'DP
Thank you
mods list
dropped compression
eagle rods
head studs
4bar map
SF ram horm
1000cc grams
255 grams
aem rail & fpr
3'DP
Thank you
watchout221
watchout221 wrote: Tue Feb 06, 2018 5:41 am quick question could i use this map on my b16a2 and using pump gas?
mods list
dropped compression
eagle rods
head studs
4bar map
SF ram horm
1000cc grams
255 grams
aem rail & fpr
3'DP
i fully understand using this at my own risk
Thank you
