D17A2 randomly dies
Posted: Thu May 26, 2016 9:36 pm
Info
- 2002 Honda Civic D17A2 turbo
- PRB K-pro v4 with cam gear
- KManager version 4.2.6
- 50 trim turbo setup, 2.5 Motorola MAP sensor, modded RSX-S injectors, Walbro 255, NGK BKR7E
The car runs fine most of the time, cruises in vacuum, part-throttle boost, and WOT fine. I have tuned the map to be near-perfect in fueling and conservative in ignition timing, based on one of the provided basemaps.
Over the past month that I have driven the car, it has randomly died four times on four different instances. The first time at 2k RPM leaving a light. The second time at about 2k RPM leaving an intersection. The third time about 3k RPM into a first gear pull. The fourth time at around 2k cruising in 2nd gear.
Each time, the car just dies. The engine cuts off and the revs start falling, and the dash lights come on, as if I clicked the car off then back on. I've noticed each and every time, the car will loudly backfire once. After the backfire, it'll start and run normally.
I have checked,
MAP sensor (gave the wiring and sensor a shake while idling)
ECU wiring (also gave it a shake)
Timing (dead on the marks)
Grounds (cleaned every one)
The ECU detects no codes. I have enclosed a copy of the calibration. I cannot get a datalog because it happens randomly and when I'm in traffic.
I have checked,
