Rotrex ep3 low rpm driving
Bankzi
Post by Bankzi »
hi
I have kpro4 and just started out with tuning my rotrex ep3, im hoping to run the car to my local exhaust fabricator for a 3" system and wanted to check it will be ok to drive there. ive yet to datalog the car driving and under load but i have it revving to 3000rpm without hesitation or splutter, my idle is set to 870rpm through kpro but car idles at 1000rpm, i have tried adjusting the slider on idle screen which helped with it dipping off throttle but still idles at 1000rpm. Would someone please check over my datalog with it revving to 3000rpm and tell me if it would be safe to drive, i would be staying under 3000rpm when driving and under minimum load. I understand the kpro will try and correct itself in closed loop upto a certain point too, is this correct?
thanks in advance
new.kdl
fugazzyek
Re: Rotrex ep3 low rpm driving
Post by fugazzyek »
yeah the a/F is corrected on low tables by close loop
