help! tps 103%--- ect 177 iat 99--- key ON
Posted: Thu May 12, 2016 1:51 pm
last sunday i started my turbo s2000 year 2000 with a k-PRO on it for the first time....set my tps value....change my map for omni 4 bar.....everything was fine... let the car idle for 20minute.
On monday...try to restart the car ...engine won't start......??? took the laptop and take a look at the value...... tps at 103%.....ECT=177F.....IAT=95F...i took a look a the wiring diagram ...i realize they are on the same supply voltage SG3.... i took a DMM and read value at my IAT ...i got 5volt on green wire and 12 volt on red wire.....seem like ECU sending power on the signal side of the sensor
i believe the ecu is toasted....what do you guys think ????
