Msd billet distributor compatible?????
dcnxero
Post by dcnxero »
I was pondering the idea of switching over to cpr but didn't know if the msd billet dizzy would work or do i need to go back to a stock dizzy. You info would be great thank you
Re: Msd billet distributor compatible?????
The CPR (and ECU) requires distributor signals which are exactly the same as stock. In theory a MSD distributor will work. In practice we've found that anything other than a stock Honda distributor may or may not work, depending if the signals are indeed exactly the same as Honda.
