s300 v2 getting cut Need you Spunk!
Posted: Fri May 06, 2016 2:54 am
by Dennisc
Can you guys please have a minute to help me. I'm really clueless of what is going on.
I'm driving a b16 turbo in a crx on obd1 with hondata s300 v2 and boost by gear.
Now i get this strange problem that I can't pull past 4000.... Sometimes it will go to 5000 then 6000... So it varies. My ignition/fuel will get cut and my rev limiter will first go to 0...
Now today I decided to datalog it and put it on this board but when hooked up to the laptop my car pulled all the way through again... But not every time, let's say 8 out of 10 times and I'm lucky I recorded one time it didn't:
probleem.s3d
Can you guys please tell me what is going on?
Maybe it has a bad ground and the wiring is fucked?
Full specs:
Setup engine;
B16a1
Stock sleeves/ crank
Eagle rods
CP pistons (9.0:1)
Supertech valves/springs/retainers
b18c4 cams with AEM Cam gears
B18C6 inlet with AEM fuel rail & FPR
Turbo:
turbonetics T3 super 60 with full 3" exhaust
TIAL 38 mm MVS wastegate 14psi
TIAL 50 mm blowoff valve
fuel;
255lph Walbro
1000 cc Injector dynamics
Electronics;
Hondata S300 V2 (with boost by gear available)
Hondata 4 bar map sensor
AEM uego wideband in D10
AEM boost gauge
AEM oil pressure (stock oil pressure sensor removed)
AEM oil temp
Re: s300 v2 getting ignition cut when boosting
Posted: Fri May 06, 2016 9:33 am
Please post the calibration that it was running from when the datalog was made.
Posted: Mon May 09, 2016 8:42 am
by Dennisc
I hope it was this calibration:
Dennis B16A 60trim OUD.skl
Help is highly appreciated because I can't seem to fix it... I think it has something to do with a bad ground and that my boost solenoid doesn't have enough ground to take care of the boost level...
Posted: Mon May 09, 2016 8:58 am
by Dennisc
I see that my PWM in the file when it fails is 50% and when it works it is 35%... It probably has something to do with that? As stated above I'm running boost by gear.
EDIT: and it seems like my injectors are getting cut not my ignition?
Posted: Mon May 09, 2016 9:40 am
You appear to be hitting a lean cut from your protection settings. The engine is also running extremely hot.
Posted: Mon May 09, 2016 9:43 am
by Dennisc
Well it has never done this before... And when I hooked up the laptop it worked? Can you explain that also?
And the weather is very hot atm here so I think that's why...
Please help me a little further...
Posted: Mon May 09, 2016 11:07 am
Have you tried disabling the lean protection to see if that makes it stop?
Posted: Mon May 09, 2016 1:34 pm
by Dennisc
Nope, I'm afraid that I could hurt my motor?
Posted: Mon May 09, 2016 2:34 pm
Then you might want to consult with your tuner about the issues you are having so they can make sure it is running safely.
Posted: Mon May 09, 2016 2:46 pm
by Dennisc
Sure that's always the last resort. But I've been running the car like this for almost two years now, I don't understand why I'm having these troubles all of the sudden... :( But you can't help me it seems?
Posted: Mon May 09, 2016 3:12 pm
You could try adding fuel in the places it is going lean, but you should probably leave that to your tuner since there may be some other reason that it is now running leaner than it was.
Posted: Mon May 09, 2016 4:00 pm
by Dennisc
Yes I was thinking about that also... I do have one last question, why is my PWM going to 50% when I make a pull even though my max pwm for high boost is 45%? And I recorded a pull when the car was pulling fine and I thought it was on high boost also and my PWM is 35% over there? Can't seem to figure it out why this is...
Would trying a fixed duty cycle of 35% help?
Posted: Mon May 09, 2016 4:47 pm
You have the high/lowboost set to always on so it is reading from the high boost tables and they are set to 45% and there is IAT compensation of 5-6%. This equals 50%.
Posted: Sat May 14, 2016 12:00 pm
by Dennisc
Thanks for the tips already.
You said I could make my map richer, so I had the idea of increasing my FPR from 43 psi to 48 psi and my car was much richer and when in boost i was always around 12.0 AFR so I don't think it runs lean...
But I kept searching and comparing my .s3d files when the car ran well and when it didn't.
And I found out that when my car gets cut that the "TC limit (ecu)" goes to 60%, please see screenshot (it's a save link from my dropbox):
https://dl.dropboxusercontent.com/u/557 ... Climit.jpg
And I'm not using any of the traction control features...
Am I missing something here? (I also suspect that my car started doing this after I updated my hondata version)
Current version: 2.5.2.0
I have s300 v2 with PWM and I think my serial is: 25436
Extra: my normal s3d file when the car pulled fine:
https://dl.dropboxusercontent.com/u/557 ... ormaal.s3d
Thanks again for all your time if you read this.
