Missing Columns In Boost Tables
Posted: Sun May 01, 2016 8:10 am
by blackek4
Hello,
I've noticed that when using the boost tables, you can't view the additional columns, in the Knock/WOT maps.
Wasn't it supposed to show the columns in all maps?
Tested this in V4.2.5 and 4.0.8 of KManager and the behavior is the same.
How can i tune the missing columns?
Thanks in advance
Re: Missing Columns In Boost Tables
Posted: Sun May 01, 2016 5:26 pm
Those tables only have 10 columns.
Posted: Tue May 03, 2016 2:43 pm
by blackek4
ok, but what is the behavior when the map sensor readings are bigger than the last value of the table?
it assumes the last value of the highest map value of the table for that rpm? or just ignores the table?
Posted: Tue May 03, 2016 3:54 pm
You can rescale the columns if you need to go higher in boost.
Posted: Wed May 04, 2016 2:07 pm
by blackek4
Spunkster wrote:You can rescale the columns if you need to go higher in boost.
I would, but it doesn't let me rescale the load columns in those specific tables. The option when you right click the load columns is greyed out.
Can you clarify about what happens when the map sensor readings are bigger than the last value of the table?
Is there any kind of limitation that forces these tables to only have 10 columns?
Sorry for all the questions, but i really want to try to understand this, to figure out the best way to get around this.
Posted: Wed May 04, 2016 4:40 pm
All the fuel and ignition tables have this option in K-Manager. What table are you referring to?
Posted: Wed May 04, 2016 5:00 pm
by blackek4
I'm refering to Knock/WOT tables.
Posted: Thu May 05, 2016 9:16 am
Those tables just read from the last column when you go higher than that value.
