Flashpro basemap advice!
Posted: Fri Apr 01, 2016 9:45 am
by accretian
Hi.. I have a takeda sri with p2r throttle body spacer and was wondering which intake map should i be using? Aem, injen, fujita or weapon-R?
Also, should i be using the regular or the race calibrated intake maps?
Thank you!
Re: Flashpro basemap advice!
Posted: Fri Apr 01, 2016 10:57 am
You may have to try different calibrations to see what works best with your parts. We no longer recommend or support the race calibrations as the normal AFM calibrations have the ability to be tuned via MAP now.
Posted: Fri Apr 01, 2016 11:57 pm
by accretian
Thanks for the reply!
So don't use the race calibration that comes with the Flashpro manager? so just use the RRB maps?
Posted: Sat Apr 02, 2016 4:53 am
by pepperdanky
If you are not going to have the car tuned, you will be better off using the race calibration basemap since you do not have a stock intake.
Posted: Sat Apr 02, 2016 3:36 pm
by accretian
Thanks! :D Takeda SRI is not listed on the options! What should i go for? kn, injen, aem , weapon r or fujita?
Posted: Sun Apr 03, 2016 11:50 pm
by accretian
i already tried aem and fujita maps.. the aem sri regular map seems to run better than the fujita sri regular map..
Also tried the aem sri race map. the car seems to be a bit more aggressive and rough..pulls way harder though..
Posted: Wed Apr 13, 2016 12:55 am
by accretian
so is the race calibration map safe to use though? Hondata tech said do not use the race calibrated maps ?
Posted: Wed Apr 27, 2016 12:40 pm
by MorningStar
Not that it's unsafe there is no need to run it now. You can custom tune your car off a normal AFM calibration, the race calibrations are to fixed anyway to what they intend to do. I prefer to make a custom tune to how I want my si to run
Posted: Wed May 04, 2016 10:50 am
by accretian
Thanks for the reply! i'm just running the K&N SRI map right now.. hopefully will be able to get it etuned in the next few months.. :)
