Page 1 of 2
KPRO V4 IQ3 Output
Posted: Wed Mar 30, 2016 4:34 pm
by tehlonz
10_19_15_pre_id_change.kal
Hello Hondata support.
I have a 2001 Ap1 s2000 with a PRB KPRO V4 installed.
I am currently trying to interface the KPRO ECU to an IQ3 street dash using Racepak 230-VM-EFIHOND module wired to TTL OUT (black) on KPRO.
So far , everything is being displayed on the dash aside from current AF/R ( EFI A/F 1 x539 ) , it always displays 14.70 , I was thinking this was showing ECU AFCMD , but this changed on the ECU to 14:59( viewed in the sensors tab) but remained 14.70 on dash . I see no changes to the dash stream , even when ignition is on but car is off ( should be full lean) .
Any advice hondata support can lend to this issue would be greatly appreciated.
Configs attached.
Re: KPRO V4 IQ3 Output
Posted: Wed Mar 30, 2016 4:44 pm
Are you using the stock O2 sensor in the vehicle?
Posted: Wed Mar 30, 2016 4:46 pm
by tehlonz
No stock narrowband. I have a zeitronix ZT-3 wired into analog for WBo2.
Posted: Wed Mar 30, 2016 4:51 pm
Post your calibration and a datalog please.
Posted: Wed Mar 30, 2016 4:52 pm
by tehlonz
Current calibration is attached to post.
I will grab a datalog now.
Posted: Wed Mar 30, 2016 5:07 pm
by tehlonz
Requested files attached.
racepak.kdl
Posted: Thu Mar 31, 2016 9:35 am
Why are you using a dual adapter harness calibration?
Posted: Thu Mar 31, 2016 9:49 am
by tehlonz
I'll download again when i arrive home .
Posted: Thu Mar 31, 2016 9:56 am
by tehlonz
With that said . Is the kpro4 paired to an iq3 capable of displaying this wbo2 information ?
Posted: Thu Mar 31, 2016 4:07 pm
There will be a release of software soon to allow this to work.
Posted: Thu Mar 31, 2016 5:39 pm
by tehlonz
Spunkster wrote:There will be a release of software soon to allow this to work.
So , should I not be expected to see my AF1 input to my racepak dash refreshing at this time?
3_31_kal.kal
3_31_datalog.kdl
Attached are current kal and datalog . If you notice sometime funny with the base kal (dual adapter or not) please advise, im under the impression this is a normal PRB Kal.
Once again , racepak displays 14.70 without fluctuation on the dash.
Thanks again.
Posted: Fri Apr 01, 2016 9:24 am
The current version of software does not support your version of wideband and it will not display it. You will need to wait until the release of the next version of software in which it will be added.
Posted: Fri Apr 01, 2016 9:42 am
by tehlonz
Spunkster wrote:The current version of software does not support your version of wideband and it will not display it. You will need to wait until the release of the next version of software in which it will be added.
Is there a list of supported wide bands at the current software version ?
Are you able to divulge when the next software may be released ?
Posted: Fri Apr 01, 2016 10:59 am
Only the ones listed in the analog input window.
I'm not sure exactly when it will be released. It could be in a few days.
Posted: Fri Apr 01, 2016 11:04 am
by tehlonz
Spunkster wrote:Only the ones listed in the analog input window.
Would it be possible to test using the calibrations in the drop down menu just to see read out on ththe cluster to test function but not have an accurate indication ?
Thank you for your help
