WB offset Voltage
Posted: Thu Mar 17, 2016 6:09 am
by Javcolin
Hi,
What is the highest offset voltage you can can run to be considered a good ground point?
Currently I'm using -0.1 and i was wondering if my ground is Ok. I read the other day that Hondata says if it goes above XX volts that means that the ground point was no good,but i can't find the post.
Re: WB offset Voltage
Posted: Thu Mar 17, 2016 9:27 am
If you have an offset and it is the same offset for the entire rev range then it is fine.
