09 civic si grams 72mm tb idle relearn HELP!!!
martenie007
Post by martenie007 »
I just installed the grams 72mm Dbw throttle body on my 09 civic si and tried the idle relearn procedure 3 different times to no avail.. It's not drive able at all right now and this is my only vehicle... It sits and idles in a bounce between 1500-1700 rpm... Mods include: skunk2 76mm mega power rr catback exhaust, Megan racing header and down pipe, skunk2 CAI and the grams throttle body listed above. I have flash pro but can't find any base maps that would possibly help me on this idle issue and can't data log as it just bucks in idle... Help please!!!
Re: 09 civic si grams 72mm tb idle relearn HELP!!!
What happens if you put the stock throttle body back on?
martenie007
I put the stock Tb back on and reflashed it with the base map I had on it and it works fine
It sounds like it is a problem with that throttle body, or it had a leak when installed. You could also try adjusting the throttle flow vs. opening table in the throttle section of the calibration window.
