E85 on S300 V2: B18C5 / JRSC / LHT @ 10psi? What overall fuel trim?
Black_R
Post by Black_R »
I'm coming from Crome Pro and basically starting from scratch with the S300.
I found this map:
https://www.hondata.com/forum/viewtopic.php?f=20&t=4393
And I'm on 550cc RC Saturated injectors, so this looks promising.
Just looking at the fuel options, couldn't I just adjust the overall fuel trim % to compensate initially?
In the above map, the overall fuel trim is set to 13%.
Does that mean that it's adding 13% MORE fuel? Or does that mean that it's trimming (removing) 13% fuel?
I'd like to start by adding about 20% more fuel to account for the fact that I'm running E85.
So would that be in the 33% overall fuel trim range?
Re: E85 on S300 V2: B18C5 / JRSC / LHT @ 10psi? What overall fuel trim?
Yes you can try that. negative values decrease and positive values increase.
