hey guys i need some help with hondata s300 tuning,
iv tuned alot of cars with crome, and i want to make sure i got the base right,
this is the order of things i do:
open a new basemap, lets say a p28,
set to open loop (disable closed loop)
choose a map sensor
disable everything in misc/options :knock sensor, eld, inj error, baro, alt c, ignition output.
in fuel injectors:
setting current injector size to what ever, lets say 1000cc (leave stock injector size at 240cc)
choosing injector offsets
uploading map to ecu, + dataloging
setting my tps range closed + open
starting the car, and while waiting it to warm up i play with the overall fuel trim to get good AFRS for idle, some cars want -20 some +20 some like 0, i am NOT using the "calc / calculation" should i ?
then i apply electrical load to adjust battery offsets,
set fuel pressure
lock timing/ set dizzy.
select gear ratios,
start tuning for cruise, then boost,
do i do anything wrong?
i'm asking because hondatas website says: The general approach tuning mixture is to adjust the injector multiplier (overall fuel trim) until the mixture is as close as possible to ideal while the engine is under full load. Normally this will result in the part load settings giving close to ideal mixture as well. so hondata recommands to do a pull before even adjusting idle? cant find the logic lol, please help
thanks
new here need some help with base tuning,
differentstrokes
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
