AEM 4100 Install Question
Posted: Sat Jan 30, 2016 4:03 pm
by Ichigo1187
Hello I'm new to Hondata, I just recently installed and AEM 4100 Wideband into my car, I'm using it as a secondary O2 sensor just for my A/F ratio, it was my understanding that I could wire the white output wire to my ECU (PR4 with Hondata S300 V1) so I can read A/F ratios in SManager, but for the life of me I can not figure out where to wire it to and how to set it up in SManager, PLEASE HELP! Thanks ahead of time for any advice given!
Re: AEM 4100 Install Question
Posted: Mon Feb 01, 2016 10:25 am
https://www.hondata.com/techplxwiring.html
The wire colors will be different, but the idea is the same.
Posted: Tue Feb 02, 2016 4:35 pm
by Ichigo1187
Thank you Spunkster, do you have any idea why intermittently on light throttle my TPS does not read and it will go into fuel cut? I have checked all my wiring and calibrated my TPS 3 times now and for some reason it will act up here and there.
Posted: Tue Feb 02, 2016 5:17 pm
It sounds like either a wiring issue or a bad TPS sensor.
Posted: Tue Feb 02, 2016 5:23 pm
by Ichigo1187
Thanks, I will double check everything.
