AEM 4100 Install Question
Ichigo1187
Post by Ichigo1187 »
Hello I'm new to Hondata, I just recently installed and AEM 4100 Wideband into my car, I'm using it as a secondary O2 sensor just for my A/F ratio, it was my understanding that I could wire the white output wire to my ECU (PR4 with Hondata S300 V1) so I can read A/F ratios in SManager, but for the life of me I can not figure out where to wire it to and how to set it up in SManager, PLEASE HELP! Thanks ahead of time for any advice given!
Re: AEM 4100 Install Question
https://www.hondata.com/techplxwiring.html
The wire colors will be different, but the idea is the same.
Ichigo1187
Thank you Spunkster, do you have any idea why intermittently on light throttle my TPS does not read and it will go into fuel cut? I have checked all my wiring and calibrated my TPS 3 times now and for some reason it will act up here and there.
It sounds like either a wiring issue or a bad TPS sensor.
Ichigo1187
Thanks, I will double check everything.
