fuel pump not priming!
Posted: Sat Jan 30, 2016 6:12 am
hi guys,
i have had my hondata s300 v3 for about a day and loaded a basemap on my civic turbo and everything was running perfectly. came back in this morning and not the fuel pump wont prime. put a live to it and nothing, so i thought id go back to the stock ecu and see what happens and it primed!
i firstly thought it was a relay issue or possibly jumer harness but now i cant see it being anything other than the ecu.
weve checked all the grounds and the fuel pump just isnt getting power with the hondata installed.
also when ive put the key into the start position it cranks but doesnt actually fire, whereas with the stock ecu it does run!
the green light on the hondata comes on for about a second when the ignition is on but then goes off and doesnt come back on if that helps..
do you guys think i should send it back and get it retested?
my setup is:
b16a2 block
b18c head
arp head bolts
550cc injectors
walbro 255 fuel pump
gt30 .60 a/r turbo
im really lost and cant think it can be anything else, but any help will be appreciated
my setup is:
b16a2 block
b18c head
arp head bolts
550cc injectors
gt30 .60 a/r turbo
