Ethanol 100% - Target AFR
terrorista
Post by terrorista »
Hi Guys,
I was wondering over the corrected ethanol target lambda and AFR over Stock K20 WB.
Stoich - Lambda 1
Max Power Lean - Lambda 0.7
Max Power Rich - Lambda 0.87
The Stock WB will read AFR as:
Stoich - 9:1
Max Power Rich - 6.43:1
Max Power Lean - 7.8:1
I´m really confuse once when mixing the fuel with gasoline we took a mixed lambda targets and AFR readings.
Re: Ethanol 100% - Target AFR
Just keep things as lambda rather than AFR and you don't need to do any conversions. Or simple use gasoline AFR for all fuels.
terrorista
I´ll do that! Thanks for your support!!!
