Analog cable question
Posted: Wed Jan 06, 2016 1:30 pm
by Justinthecoastie
Quick question about the analog cable(s), would I need to add in-line fuse(s) for the gauges I want to run using the analog outputs? My application is 05 S2000 using Kpro 3 software and hardware. Thank you.
Re: Analog cable question
Posted: Wed Jan 06, 2016 2:06 pm
You should not use a fuse with an analog signal.
Posted: Wed Jan 06, 2016 3:21 pm
by Justinthecoastie
Spunkster wrote:You should not use a fuse with an analog signal.
Thank you. Just making sure I use it appropriately.
