Ethanol Sensor Input Issues
Posted: Thu Dec 31, 2015 4:17 am
by Bdavis
Hi,
I am running the following
S300 V3
GM Ethanol Sensor - Fed with 12V, GND, and Vout heading to Analog Input 0.
I have verified connections and voltage. I have basically done everything I can without a scope.
I have chosen that input in the Flex Fuel Parameters, but I am not reading any input from the sensor when I data log.
Any ideas on what I could be doing wrong?
Re: Ethanol Sensor Input Issues
Posted: Thu Dec 31, 2015 5:56 am
by Bdavis
Also running 2.5.0.0
installed 2.4 kOhm resistor across Vcc (12V) and Vout.
Posted: Thu Dec 31, 2015 10:27 am
Double check the connections to the sensor and the resistor. Otherwise it sounds like it is correct.
What have you selected in the calibration? Are you running the latest software?
Posted: Fri Jan 01, 2016 7:37 pm
by Bdavis
So after letting it sit for a day, everything works. All I did in between was reboot the laptop and ecu one more time. Go figure... I'm happy :)
I am running 2.5.0.0
Posted: Sat Jan 02, 2016 9:50 am
Glad that it is working ok for you.
