Page 1 of 2
Bring back the strain gauge
Posted: Sat Dec 26, 2015 8:06 am
by rev hard
Ive noticed that a lot of people are going faster and faster on s300 now then before, is there anyway way we can bring back the strain gauge settings in s300 to maybe even further improve times , with the people running the dog boxes?
Re: Bring back the strain gauge
Posted: Sat Jan 23, 2016 11:49 am
by SPOOLIN
perhaps it was taken out because the factory ecu can't process it fast enough?
Posted: Thu May 12, 2016 6:41 pm
by rev hard
could a strain gauge with 2.5v be setup using the iat input? to cut ignition? on shifts
Posted: Fri May 13, 2016 5:44 am
It was taken out because there is very limited space in the ECU memory. Since more people are interested in using a strain gauge input we've added back in a timed rev limit for the shift cut.
Posted: Fri May 13, 2016 9:43 am
by SPOOLIN
How does that help vs adding back in the strain cut input?
Posted: Fri May 13, 2016 5:14 pm
by rev hard
yea how does this help? and how long does it cut for?
Posted: Sat May 14, 2016 5:31 am
It is a strain gauge input.
Posted: Sat May 14, 2016 6:20 am
by SPOOLIN
I don't see that in 2.5.3?
Posted: Sat May 14, 2016 9:57 am
by rev hard
this would be great...what voltage does it work on? or need to trigger it? 12v? 5 v? 2.5v?
Posted: Mon May 16, 2016 7:51 am
It has not been released yet. It functions from an off/on input, not voltage.
Posted: Wed Jun 15, 2016 6:25 pm
by rev hard
using this cut...how does the timing come back in?..does it slowly come in or does it just go back to the map instantly?
Posted: Fri Jun 17, 2016 9:05 pm
by V-Spec race development
What strain gauge brand do u guys recommend? I know it needs to be a digital ones and not voltage activated thanks.
Posted: Sun Jun 19, 2016 12:28 pm
by rev hard
Flat shift strain gauge shift knob...has a built in on/off ground signal that is adj for how touchy the trigger is
Posted: Sun Jun 19, 2016 9:46 pm
rev hard wrote:Flat shift strain gauge shift knob...has a built in on/off ground signal that is adj for how touchy the trigger is
I see that they are based in Europe, Are there any dealers in the U.S?
Posted: Mon Jun 20, 2016 12:15 pm
by rev hard
yup....speedfactory sells them...jjautowerks...few others
