b16a1 with ITR cams, use oem/stock cam gear or Adjustable Cam Gears ?
opinions ?
gabrielsousa
forevertrj
- Contact:
Re: b16a1 with ITR cams, use oem/stock cam gear or Adjustable Cam Gears ?
It is always better to use adjustable cam gears, fine tuning the lift points will change the characteristics of your motor to have a better torque or horsepower curve. I highly recommend doing some research on how changing the degrees of your cam lobes will change the characteristics of your motor.
gabrielsousa
thanks, do you know if this information is right ?forevertrj wrote:It is always better to use adjustable cam gears, fine tuning the lift points will change the characteristics of your motor to have a better torque or horsepower curve. I highly recommend doing some research on how changing the degrees of your cam lobes will change the characteristics of your motor.
INTAKE
centerline 180 + 15 + 45 =(240 / 2) - 15 = 105º
Max valve lift - 11.5 mm
Intake opening 15 deg (BTDC)
Intake closing 45 deg (ABDC)
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST
centerline = 107.50
Max valve lift - 10.5 mm
Exhaust opening 45 deg (BBDC)
Exhaust closing 10 deg (ATDC)
EXHAUST lift - 10.5mm, duration 235 @1mm
forevertrj
- Contact:
each engine will be different slightly the only way to know for sure is to measure your engine, refer to this video for help. https://www.youtube.com/watch?v=up00AC7QcZs
