Stock Car Amplifier not turning on after cal uploaded
Posted: Mon Dec 14, 2015 7:23 pm
by islandsi
2015 Civic Si Coupe. My stock stereo amp will turn on while in the process of uploading a cal, but will not turn on during day to day driving. Is there a setting I can look at somewhere?
Re: Stock Car Amplifier not turning on after cal uploaded
Posted: Tue Dec 15, 2015 10:05 am
Does this happen when you plug in the USB cable? The systems are unrelated, but if there is a bad ground then it could be grounding through the USB cable.
Posted: Wed Dec 16, 2015 1:03 pm
by islandsi
Come to think of it, yes it was plugged into the ODB and my laptop through USB. Dont suppose you have any advice? Trace the wires from the amp?
Posted: Thu Dec 17, 2015 12:34 pm
Check the engine bay grounds first - remove and clean down to bare metal. The current through the USB can easily damage the FlashPro, so be careful.
Posted: Thu Dec 24, 2015 5:18 pm
by islandsi
Well I checked - my ground looks fine and I noticed it happens even when just plugged into the ODB without USB.
Posted: Fri Dec 25, 2015 8:41 pm
Can you name which of the grounds did you remove and clean down to bare metal?
