Re: B20V NEED BASE MAP
Posted: Mon Dec 07, 2015 7:37 am
by smowkem_built
So I got tune last month and couple weeks after
My ecu throw a code cam position sensor, and now it's on
Limp mode. I transfer my s300 v3 to my friend ecu no codes but still in limp mode can't pass 3500...
Help anyone I've been trying to call hondata but no luck since I'm from Oahu Hawaii different time..
S300 v3 limp mode won't pass 3500
Posted: Mon Dec 07, 2015 8:18 am
by smowkem_built
I was driving around and all of sudden it throw a cel code it was cam position sensor/crank angle sensor, I couldn't clear the code I even tried changing map to Itr base but same result won't pass 3500 rpm
So I tried putting my extra chipped p28 no cel car runs good. So I tried putting my s300v3 on a different ecu no cel but won't pass 3500 still.. ive tried switching around the s300 and I'm pretty sure it's s300 itselft
Sn: s300-33852
Software 2.5
Itr base
P28
B20v obd1 obd2 injector clip solder.
Msd distributor...
Limp mode, won't pass 3500
Re: S300 v3 limp mode won't pass 3500
Posted: Mon Dec 07, 2015 10:33 am
Have you tried your ECU/s300 in a known working vehicle?
The chipped ECU may be setup to ignore certain errors.
Posted: Sun Jan 24, 2016 4:05 am
by smowkem_built
its running good now transfer the s300 on a different ecu and played with the settings...
Posted: Sun Feb 07, 2016 1:34 pm
by datsrht2
I'm having the same problem, what settings did you play/change on the s300 to get things going good???
Posted: Sat Dec 12, 2020 4:28 pm
by MadMatt93
Was this figured out??
