Upgrade MAP sensor from Stock to Hondata 4bar
Posted: Fri Nov 20, 2015 3:44 am
Hi Hondata,
I received the new Hondata 4-Bar MAP sensor for the FN2 because my S/C kit makes more then 10.5 PSI of boost.
So the stock MAP sensor is on the limit...
Question:
> After install the new 4-bar MAP sensor and select the 4-Bar Hondata sesnor in the FlashPro Calibration - any other modification in the cal is required?
(Modify fueling etc.)
Question:
