S300 hardware problem
Posted: Sat Oct 31, 2015 2:55 pm
- serial number of the s300 inside the ECU
Serial > 12,396 S300 v1
- version of software being used (Help, About)
2.5.0.0
can´t datalog
- what sort of vehicle you have
Honda Civic Coupe d16z6 - turbo
- what sort of ECU you are using
p28 manual
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
Nothing
S300 v1, never had a single problem with it for 4 years. Today, after 20 days without even look at the car, didn´t work at all.
- CEL Always on
- Poor idle and revs, can´t run.
- Can´t comunicate with ecu properly - cant see real time parameters, cant see or erase DTC´s
- It uploads(or at least shows on the software)
- Erase ECU doesn´t work.
- D1 led always red.
- D2 led sometimes is green, but mostly off.
- D4 green
What I have tested so far:
- Another ECU - same problem
- Change the 20m cristal of the s300 - same problem
I usted to work for a dealer here in Brazil, I have good soldering skills and knowlege of eletronics, if you could help me fix this would be great, 330usd to ship the s300 to you would be a great cost right now(4:1 currency ratio today in Brazil) - it is my personal project car.
Contact email - fhcampos@gmail.com
2.5.0.0
can´t datalog
p28 manual
Nothing
- CEL Always on
- D4 green
