Help eg Hondatas300 shift light always on with new basemap???
1JDMEG
Post by 1JDMEG »
Hi I currently have a hondatas300 v3 running a basemap before that wasn't good. I downloaded a better basemap seems to be running better than before all low end power crushing etc. it's just a little rich at boost about 10.3 afr. I will get it tuned soon. The weird problem is that it has this shift light constantly on all the time. I know j can adjust shift light that is the check engine light coming on but the oem shift light is solid. How do I remove this shift light I uploaded other maps but this one just seems to stay on all the time.
Can anyone help does anybody know how to remove this shift light
Re: Help eg Hondatas300 shift light always on with new basemap???
Without the calibration and a datalog showing the issue it is hard to say what it could be.
1JDMEG
Post by 1JDMEG »
I mENT the up shift arrow is on solid. the engine light isn't on.
1JDMEG
Post by 1JDMEG »
Can I send u the map and would u know what's causing it? Need some help
What vehicle is this, and what ECU are using using?
1JDMEG
Post by 1JDMEG »
I am using a p28h0ndataS300v3 installed ecu I uploaded this map due to the basemap I received was running super bad rich even at idle this map is better also has power at low driving conditions etc,
It works just the arrow is on all the time
