Kpro v2 on a PRA ecu in a DC5 type r
Posted: Tue Oct 27, 2015 1:22 pm
by sabberjoch
Hi guys,
I'm running a Kpro V2 on a PRA ecu. This is put in my dc5 type r (which has an PRB ecu stock).
Now my o2 sensor doesn't read the volts. So it gives a constant a/f of 14.7.
I'm not sure if it was like this from the beginning, i thought it was reading fine at first.
Do i need and narrowband or wideband o2 sensor for this ecu? if i need a narrowband, could i hook up the secondary sensor?
Re: Kpro v2 on a PRA ecu in a DC5 type r
Posted: Tue Oct 27, 2015 4:56 pm
The PRA uses only a narrowband sensor and cannot read a wideband signal even if a wideband sensor is installed.
Posted: Wed Oct 28, 2015 12:02 am
by sabberjoch
Ok thanks, so which sensor would i need for the kpro to read it?
Posted: Wed Oct 28, 2015 4:24 am
by sabberjoch
I just checked an old datalog. And it did read the voltage of the primary o2 (denso wideband). However it seems it didn't give out an a/f ratio. Voltage was between 0 and 1 volts. At the moment it constantly reads 0 volts, and gives the p135 error code.
Posted: Wed Oct 28, 2015 8:56 am
You would have to use the narrowband sensor and rewire the car to be the same as a Euro spec car.
It would be a lot easier to use a PRB ECU.
Posted: Wed Oct 28, 2015 9:12 am
by sabberjoch
I'll add the datalog, as you see it does read the o2 sensor (wideband denso) at this point.
At the moment it doesn't anymore, so i guess the wideband sensor has died on me.
Is it possible to use a narrowband to function for the closed loop?
I can always use an external wideband for tuning purposes.
Posted: Wed Oct 28, 2015 9:34 am
As was previously said, you will be much better off just using the PRB ECU in the vehicle and the original wideband will work with it with no wiring modifications needed.
Posted: Wed Oct 28, 2015 10:19 am
by sabberjoch
Don't have the original ecu anymore. How much Harm can it do driving in open loop? Not using the sensors At all. I can hook up a separate wideband at my tuner (sneaky tuning in the netherlands)
Posted: Wed Oct 28, 2015 11:27 am
YOu will not be able to run in closed loop using an aftermarket wideband and will only be able to use it for datalogging. IF you upgrade to the V4 K-Pro then you will be able to run closed loop off of an aftermarket wideband with the PRA ECU.
Posted: Thu Oct 29, 2015 11:52 am
by sabberjoch
Problem solved, made a stupid mistak. Checked the ecu, it is a prb. The map that was installed on the ecu previously was made on a pra basemap. So it had the pra software. Just used a prb ecu and the wideband works again!
