Cold temps Flashpro does not work - temp speccs available?
Posted: Thu Oct 15, 2015 11:24 pm
Hi,
I had the problem that the Flashpro does not work in the morning supposably reason at the moment we have cold temperatures here in Germany 3 - 9 C°.
My FP is mounted in the car and connected all the time to the CAN. But it was dead and I could not start logging. No blinking LED etc.
... I could fix the issue after warming up the car and set up the air ventilation to high. After that the environment from the car was approx. 15 - 20C°.
After the ride to the work I re-connected the FP to the CAN and viola the FP takes a deep breath and it was still alive.
> Thank God! the FP is not damaged.
I am very happy if you could provide the performed tests of the temperature which the FP will operate stable.
Regards
Regards
