IAT Sensor Causing Car to Not Start
Posted: Mon Oct 05, 2015 1:02 pm
Hello all,
I am new to this forum but have been present on 8thcivic for a few years now. I just finished relocating my iat sensor to the charge pipe before the throttle body on my greddy turbo build. When plugged in, the car will intermittently not start when the iat is plugged in. When it doesnt start, the fuel pump does not prime and my dash lights are lit up very dim like so:
If I unplug the sensor, the car starts up, but i get a cel for "Intake Air Temperature Sensor High Input" and VSA lights on:
The way the sensor is wired is similar to how it is done in the Hondata DIY, except instead of tapping the two wires, they were cut and soldered to the pigtail:
I am confused about how the wiring of this sensor, be it a bad sensor or pigtail, is causing the car to not start. Anyone have any suggestions? For reference, I have posted the links to the sensor and pigtail that I purchased.
PIGTAIL: http://www.ebay.com/itm/181824748692?_t ... EBIDX%3AIT
SENSOR: http://www.amazon.com/gp/product/B00I87 ... ge_o02_s00
Thanks for the help!
EDIT: It turned out to be loose and corroded battery terminals. So when fiddling around in the engine bay, the terminal would get knocked loose. Then when leaning back in to unplug the iat, I must have kept knocking the terminal into place. It would consistently happen, which is odd... but changing the terminals fixed it.
