DTC P0341 dissable option
Posted: Thu Oct 01, 2015 8:57 am
by Josie
Hi Hondata,
It's possible to dissable the DTC P0341 code from the ECU like the K-pro? I can't see any option to do it.
We have some issues with a JUN Type 3 cams , double check the degree and all it's OK but the ECU fall into DTC code.
thanks
Re: DTC P0341 dissable option
Posted: Thu Oct 01, 2015 3:58 pm
The ECU is generating this code because the relationship between the intake and exhaust cams is incorrect. Disabling the code in the ECU will not fix the problem.
Posted: Fri Oct 02, 2015 1:52 am
by Josie
Yes Sir ,
but its not a cam timing problem , the aligment marks and cam degree it's ok , the problem is on the intake cam signal sprocket , it's not aligned with exhaust well and have no regulation option as you know.
We had that issue with another cams in a Kpro system and using the DTC error dissable option was great.
