2011 TSX MT Flashpro Rev Hang
Posted: Thu Sep 24, 2015 12:01 pm
by TSX6MT
Does Flashpro for a TSX 11 MT control the overrun throttle compensation (OTC) and fuel cut delay (FCD)? I'm interested in eliminating rev hang but don't really want a tune. Basically, I'll like to know if I can buy a Flashpro, download the basemap and play with the overrun throttle compensation (OTC) and fuel cut delay (FCD) at will?
Thank you
Re: 2011 TSX MT Flashpro Rev Hang
Posted: Thu Sep 24, 2015 12:55 pm
I would recommend that you download the software and you can then see exactly how it all works.
Posted: Thu Sep 24, 2015 1:32 pm
by TSX6MT
Thank you! I didn't know you could download the software w/o purchasing the system firsts. I'll definitely will do that!
Posted: Sat Sep 26, 2015 6:56 am
by iselfdevi
Reducing the overrun feul cut delay doesn't get rid of rev hang. It will just make the motor jerky when letting off the pedal. Is there going to be an option that will actually get rid of it??
Even with it set to 10 or 20, the rev hang was still there.
Posted: Sat Sep 26, 2015 9:40 am
We will add the throttle closing parameter to the next release.
Posted: Thu Oct 29, 2015 12:52 pm
by iselfdevi
Rev hang is now gone on my 12 tsx with the newest release. Is there a way to make it less "jerky" when letting off the throttle?
Posted: Thu Oct 29, 2015 3:15 pm
by pepperdanky
Set the overrun fuel cut delay back to stock and/or reduce the overrun MAP settingss.
Posted: Thu Oct 29, 2015 4:26 pm
by iselfdevi
I do have then at stock settings. I'll try your second suggestion. Should I maybe raise the stock settings past the stock 90ms?
Posted: Sat Oct 31, 2015 1:45 pm
by ssjoeboe9
Can the "Overrun throttle opening" also be added to 2009/2010 TSX? Option is only available for 2011+ at the moment
Posted: Mon Feb 01, 2016 5:47 am
by Cu2suspect
I set mine to 40 for each gear and it shifts great for me, also tuned by vit
