Hondata Ignition calculation
Artem-makarchuk
Post by Artem-makarchuk »
How Hondata calculate ignition advance ?
For example:
Base timing 16*
Value in ignition table at idle 20*
Value in ignition table at WOT at 7000rpm 28*
How much ignition advance will be in the engine ???
Re: Hondata Ignition calculation
It depends on the ignition compensations you have set: http://www.hondata.com/help/smanager/ig ... b=ignition
Artem-makarchuk
I know about Ignition Compensations.
I tell about other thing.
If i put in ignition table value 40* - engine will be work at 40* ignition advance ??? (If all ignition compensations will be 0)
It should be.
