Page 1 of 2
P0132 error code
Posted: Mon Sep 14, 2015 1:58 am
by Tsuchinoko
Hello i'm tuning a K20 itr swaped car and this code is not going away.
Normally I delete this code by enable Narrowband (secondary oxygen sensor) - PRA on closed loop operation options, BUT on these case i'm using a V4 Kpro and i'm using the funtion External wideband -Kpro Input (V4 only).
How can I manage to get rid of these code?
Re: P0132 error code
Posted: Mon Sep 14, 2015 6:38 am
by sam_eg4
I get exactly the same P0132 on my newly bought EG6 with K20A2, KPro v3 in PRA ecu. Autometer 6171 wideband is connected on E15 ELD pin, no primary or secondary O2 sensors installed.Kmanager 4.1.5
O2 voltage (in sensors section) shows 4.08-4.10 Volts.
P0132 appears 115 seconds after ignition on.
Can't get rid of P0132.
Give a newbie any update please )
Posted: Mon Sep 14, 2015 7:34 am
Tsuchinoko: You'll have to tell us more information - the calibration would be good. PRB calibrations should not get P0132 errors so are you using a PRA calibration?
sam_eg4: You can't run in closed loop from the Autometer, so either you'll have to disabled the o2 sensors completely and run in open loop, add the factory o2 sensor or use the wideband's narrowband output (if the Autometer supports it). Again, the calibration would be good.
Posted: Mon Sep 14, 2015 7:55 am
by sam_eg4
Yes, I run in open loop, I have closed loop operations disabled & I have P0132.
Posted: Mon Sep 14, 2015 8:17 am
by Tsuchinoko
It's a PRA ecu and is a PRA calibration.
Posted: Mon Sep 14, 2015 12:47 pm
Can you send calibrations? I will then test them out.
Posted: Mon Sep 14, 2015 1:06 pm
by Tsuchinoko
Here you have, many thanks.
Posted: Tue Sep 15, 2015 11:04 am
by sam_eg4
Mine one here )
Posted: Tue Sep 15, 2015 12:10 pm
Thanks for the calibrations. We'll remove that error from the next release when in open loop.
Posted: Fri Sep 18, 2015 2:25 am
by sam_eg4
Solved. :) Grounded A6 pin via 40kOhm resistor.
Posted: Thu Sep 17, 2020 5:37 am
by ominus1000
hello and sorry to bring that post back.I have a eg9 k-swap with pra ecu and k20a2 uk ep3 engine but when i enable the close loop with the primary narrowband sensor i always take the error p0132 and error on heater circuit malfuction.
The car is tuned in open loop with pra calibration and the harness is fixed like tha diagram for pra ecu from hondata is any idea to help to fix this
Any help will preciate
Posted: Fri Sep 18, 2020 12:08 pm
What diagram are you referring to?
Posted: Sat Sep 19, 2020 2:44 am
by ominus1000
I have make the connections for narroband sensors like this link https://www.hondata.com/tech-euro-ctr-o2-wiring
But still i take errors like p0132 and heater circuit malfunction for primary o2 in close loop
Posted: Mon Sep 21, 2020 9:03 am
That wiring is for an OEM wideband sensor and you are trying to use a narrow band sensor. This will not work.
Posted: Mon Sep 21, 2020 10:31 am
by ominus1000
On the first diagram is for pra with oem narrowband sensor
