New injectors
Posted: Sat Sep 12, 2015 7:00 am
by sean
Hello,
Re: New injectors
Posted: Sun Sep 13, 2015 12:14 pm
by sean
Hey so Iv downloaded the hondata
RDX-2007-9K&NCAI-600CCDW tune and I just changed the injector calibration from 600cc to 850cc injectors. The car ran fairly strong....noticeable difference from before even if i did not push it past 30% throttle, Iv uploaded my datalog just me going around the block, and all the settings seem to be working well...idle is smooth and should get smoother after a couple cycles and throttle response is good...it seems like the program is doing everything it should and doing it well, however I do have one question. On my datalog my engine knocks twice. Once in cylinder 2 and the second in cylinder 3, both knocks are around 2000rpm accelerating from a stop sign using 20% throttle. I was thinking maybe I have bad gas ( The car was sitting a long time while I was making the exhaust and the gas tank is beyond empty. whats left inside the tank is currently 91 octane and i think i will make a permanent switch to 94.) Maybe i sucked in water or maybe i need to run a colder plug??? anyone know of a spark plug that will work with my setup?
mods are
-3.5"
-3" exhaust
-K&N filter ( not CAI )
-850cc bosch injectors
-hondata tune (listed above)
Any body have any comments It would be appreciated
Heres the Datalog
datalog hondata 600cc dw injector Tune ( using 850cc bosch).fpdl
Re: New injectors
Posted: Tue Sep 15, 2015 10:27 am
by D-Rob
One or two knock counts in those areas are fairly minor.
I do suggest having the car tuned, though. The trims are all over the place.
Myself, along with a few others offer remote tuning services for this application.
Re: New injectors
Posted: Tue Sep 15, 2015 5:12 pm
by sean
Ok, I'm definitely going to get it tuned but I was going to consider a dyno tune, if you can make a tune that will help make the car run better than I am all ears , it would be a temp fix until I go to the dyno
Problems
- rough idle...especially when AC is on
- s trim at idle is 5-10%....with a 14.6-15:1 air fuel ratio BUT the car smells like it's running extremely rich. If I'm stuck in traffic I will die ( no cats)
-possible map sensor problem ( threw an over boost code last night 16psi) map should read to 25 np.
- would like to fine tune the timing and boost, I think there's still a lot of room to play with.
Let me know what you think Rob, and what the pricing would be
Re: New injectors
Posted: Tue Jan 05, 2016 12:34 pm
by the_wrench116
are you on acurazine? how did it turn out?
Re: New injectors
Posted: Sun Feb 07, 2016 7:38 pm
by sean
No, not on any forms...still woring out problems...would like the car to be done properly before I post it up on acurazine...so far mods are 3 inch exhaust to muffler ( heat wrapped ). 850 cc injectors, cold air intake ( a massive one ) and a front mount....noticeable difference over stock....before i did the front mount and intake i was running low 14s...like 14.30s and was hitting 60 in about 6 seconds. Then i had the car dyno tuned...not sure how it happened but according to the tuner i was making 240whp and 330 wtq....took it back to the track and lost 2 seconds on my 0-60 and was running high 15s.....got my money back...and reset the car to my last tune....after the front mount and the intake and a custom tune by yours truly ...my best 0-60 time was around 5.3....have not had the time to bring it to the 1/4 but im hoping to bust into the 13s this year. Im still trying to get all the bugs out and have it run well before i take it to a dyno tuner again....i believe there is still a lot more left in this engine.
Re: New injectors
Posted: Fri Feb 16, 2018 6:13 pm
by boosted11
Where did you get your RDX tuned that they did that bad ??
