unexpected rev limiter on ~2K Rpm
Posted: Fri Sep 04, 2015 1:12 pm
by military
after some race I have unexpected 2k rpm rev limiter- no error codes, when cutting - quick off/on ignition let rev normaly for some seconds, when revs down to 1K, then again - problem appear.
any suggestions?
Re: unexpected rev limiter on ~2K Rpm
Posted: Fri Sep 04, 2015 1:46 pm
From Help, About, what version of software are you using?
Posted: Sat Sep 05, 2015 5:04 am
by military
used latest version till 09-04 update, after soft update (09-04) cant recall this bug 2 days of testing in garage.
Can this coul be bug from software?
Posted: Sat Sep 05, 2015 7:55 am
You need to get the latest software (which is why we asked you the version number), then upload your calibration to the s300 again.
Posted: Sat Sep 05, 2015 8:30 am
by military
do that, problem diasapier for now (problem shows not everyday in past), could it be soft problem? could be software update is my problem resolve?
Posted: Sat Sep 05, 2015 11:30 am
by AREA876
Are you using the current version 2.4.5?
Posted: Fri Nov 13, 2015 11:16 pm
by CheapnCheerful
I have the same problem, have the latest software, no codes, tried resetting, tried downloading then uploading, no resolution.
Exact symptoms are; 2k rev limit in any gear, complete cutoff from fuel until rpm falls below 1k, regardless of throttle, but no rev limit out of gear, aside from LC rev limit. As soon as it hits said LC rev limit in neutral, it cuts fuel until rpm is below 1k again. Very odd, need solution urgently as the is my daily driver.
Posted: Sat Nov 14, 2015 11:47 am
by AREA876
Post your current calibration and a datalog showing the problem
