Flashpro locking problem
o9si
Post by o9si »
Hello, I purchased a used Hondata Flashpro for a 2009 Civic Si. I bought it using Hondata website's guidelines on how to verify the unlocked status. Everything checked out... But I am getting an error message trying to enter my VIN on the Hondata program.
"Could not lock the FlashPro to this vehicle
Entered VIN does not match recorded VIN"
Am I doing something wrong?
Thanks for the help.
Re: Flashpro locking problem
What VIN are you trying to enter?
In FlashProManager under the FlashPro window compare the VIN (under vehicle) with the VIN you're entering. They should be the same unless the ECU was swapped at some point.
o9si
Post by o9si »
I am trying to enter my VIN from a 09 Si. The FlashPro program tells me the VIN is unlocked and there are no security passwords. It let me delete the previous owner's info (name, email, number), but still getting the error
What is the serial number of the FlashPro? Has it been plugged into your vehicle yet?
o9si
Post by o9si »
I have not plugged it into my vehicle yet. Serial number
You must plug it in to your vehicle before you can lock to it.
o9si
Post by o9si »
And if this doesn't work, what is the solution? I appreciate the help and fast replies.
That is the solution.
o9si
Post by o9si »
Thanks a lot.
