Won't start cpr
Phillipjuice
Won't start cpr
Post by Phillipjuice »
I hav a 00 si with obd2b wire harness using a jumper harness to obd1.. do you need a distributed in place to run the kit becuse my supplier said no and sold me a cam cap to put in its place.. Now I'm reading the wiring diagram it shows its hooked up and would only make sense becuse it has no other source of reading timing.. Second is I hav no tac wire on the obd2b harness this will not effect anything becuse it's a out put signal correct? just wanted to ask the basic questions that I hav not seen asked b4 thanx
Re: Won't start cpr
You must have a distributor for this to work. You may have to tap the wire for the tach signal to the CPR harness.
