Re: Help Install PLX wideband
Posted: Wed Aug 19, 2015 4:48 pm
Posted: Thu Aug 20, 2015 11:32 am
You will need to look at the documentation that came with the wideband and then use the instructions we provided to wire it to the ECU.
Posted: Tue Jan 19, 2016 6:35 am
by Xtremebb20
not sure where to post this ? so its going here. I just installed the PLX wide band module gen 4 in my crx and removed the R136 and R138 resisters now I'm getting code 43 on smanager and P0169 on the hondata app. code is for Fuel Compensation and was wondering how I can fix this. I seen that my S. Fuel trim dips to -30 and that activates the cell after that is stays around 2 the a/f is at 13.22 any thoughts? Engine is spuddering while under steady throttle. I also looked at the datalog and my Short Fuel trim is all over the place. I attached a datalog to see if this helps.
Posted: Tue Jan 19, 2016 10:29 am
It probably needs to be properly tuned.
Posted: Tue Jan 19, 2016 10:40 am
by Xtremebb20
yeah I figured that lol. I just got all of it put together and now it don't run right. oh well Humble is 2 hours away.
Posted: Tue Jan 19, 2016 10:41 am
by Xtremebb20
hey spunkster did you get a chance to check out the datalog?
Posted: Tue Jan 19, 2016 11:40 am
It's really hard to tell anything from just a datalog and no calibration, but it sounds and looks like it is probably just a tuning issue and once properly tuned should run properly.
